D4RK1 0
I have a lamp in my dining room which is controlled via fibaro rgbw controller. I am using the second switch (s2) on a fibaro double switch to control it. The 12V power supply I use is making noises when not at 100%, I already ordered another but the noise has made it possible to detect the problem.
I guess I haven´t set the proper settings because I would like to control the rgbw with a single switch (On/Off would be ok, Dimming would be great, Controlling Colors is not necessary via wall switch). On/off works fine mostly but when I try to dim the light (holding the switch), it seems to be working but not in a way that is helpful. It only dims down, double clicking doesn´t set it back to 100%. So far I have been setting it back to 100 via the App and just turning it on and off. But I have a wife and two kids and sooner or later one of them will push the switch too long and accidentally change the dim level.
I have tried around with the parameter settings, but I can´t get it to work the way I want it to.
Another thing is, when changing the dim level via wall switch it doesn´t seem to affect the settings in the HC2, it is still showing a 100% even though the lamp is visibly not at maximum (and making noises). When I use the sliders in the HC2 or App and slide them to say 50% and back to 100% the lamp goes back to maximum.
Can anyone tell me what I am doing wrong?
4 answers to this question
