scene trigger does not work
Quote
I found this scene. I got the open/close window part to work. if i open my window this part is triggerd elseif (trigger['type']=='property') then
But I can't seem to get the scene to trigger if global variable Niemandthuis is changed.
a change of Niemandthuis should activate his part if (trigger['type']=='global') then
%% properties
152 value
%% globals
Niemandthuis
--------------- Absenk-Temperatur bei Fenster-Öffnung-------------
local schedule = {
id = 10, --ID des Raumes im Heiz-Panel
idleTemp = 16 --Temperatur, die bei Fenster-Öffnung gesetzt werden soll
--------------- Absenk-Temperatur bei Abwesenheit ----------------
local scheduleAway = {
idleTemp = 10 --Temperatur, die bei Abwesenheit gesetzt werden soll
sensorID = 152 --ID des Tür-/Fenstersensor
-- AB HIER NICHTS MEHR ÄNDERN
    function Debug( color, message )
     fibaro:debug(string.format('<%s style="color:%s;">%s<!--%s-->', "span", color, message, "span"));
    local function getMethod(requestUrl, successCallback, errorCallback)
      local http = net.HTTPClient()
      http:request(requestUrl, {
      options = {
       method = 'GET'
       success = successCallback,
       error = errorCallback
    local function putMethod(requestUrl, data, successCallback, errorCallback)
      options = {
       method = 'PUT',
       data = json.encode(data)
    local function setVactionModeTrue(subjectToChange)
      local url = 'http://127.0.0.1:11111/api/panels/heating/' .. subjectToChange.id
      getMethod(url, function(resp)
      if resp.status == 200 then
        print('Er is verbinding met het heating panel ' .. resp.status)
        local panel = json.decode(resp.data)
        if panel.properties.vacationTemperature ~= nil then
          panel.properties.vacationTemperature = subjectToChange.idleTemp
          print('Zet de tempratuur naar ' .. subjectToChange.idleTemp .. ' C')
          putMethod(url, panel, function(resp)
            print('verandering wordt toegepast.')
            end,
            function(err)
            print('Error ' .. err)
            else
            print('heating panel niet gevonden')
            else
              print('verbinding kon niet worden gemaakt ' .. resp.status)
            end,
            function(err)
              print('error ' .. err)
    local function setVactionModeFalse(subjectToChange)
        print('Er is verbinding met het heating panel' .. resp.status)
          panel.properties.vacationTemperature = 0
          print('programma word hervat.')
              print('verandering zijn toegepast.')
            end,
            function(err)
            else
            else
            end,
            function(err)
    local trigger = fibaro:getSourceTrigger();
  if (fibaro:getGlobalValue("PresentState") == "Afwezig") then
    if (tonumber(fibaro:getValue(sensorID, 'value')) == 0) then
      setVactionModeTrue(scheduleAway)
      Debug("blue",'Afwezig, niemand thuis, verwarming verlagen.')
    else
      Debug("white",'Afwezig, niemand thuis, raam is open. Tempratuur blijft hetzelfde.')
  elseif (fibaro:getGlobalValue("PresentState") == "Aanwezig") then
      setVactionModeFalse(schedule)
      Debug("red", 'aanwezig, er is weer iemand thuis. volgt programma.')
    else
      Debug("white",'aanwezig, er is weer iemand thuis. raam is open. Tempratuur blijft hetzelfde.')
      if (tonumber(trigger['deviceID'])==tonumber(sensorID)) then
        local sensor = fibaro:getValue(sensorID, 'value')
        if (tonumber(sensor) == 1) then
          Debug("yellow", 'raam is open.')
          counter = 0
          while (tonumber(fibaro:getValue(sensorID, 'value')) == 1 and counter < 60) do
            counter = counter + 1
            fibaro:sleep(1*1000)
        if (tonumber(fibaro:getValue(sensorID, 'value')) == 1) then
          Debug("blue",'raam is nog open., er word gelucht. verwarming naar laag.')
          setVactionModeTrue(schedule)
        else
          Debug("yellow", 'raam is binnen een minuut weer dicht.')
    else
        fibaro:debug('raam s dicht.')
        Debug("red", 'raam is dicht. volgt programma.')
Hi!
how do you understand what script not triggered by Niemandthuis global?
I can't see any debug code for this action.
add code like this before
    it works now but i do not know what i changed:P
