My HCL after update to v.4.16 freezes up each night few seconds after midnight. Also when I'm usin the web interface it stops working quite often and shows the 'service unavailable' error message. I have an impression that with each update the HCL is less and less stable, now it's almost not usable!
Run through your scenes and make sure that they do not call lamps ect. that are either no longer present or has changed ID. Look especially for scenes that use a midnight variable - as I guess you use.
Then make a backup and unplug the Homecenter from current (not just reset it) for at least 10 minutes. Replug it and hopefully everything runs as expected.
Edited by Thomasn
I have been experiencing the same issues with several HCL's; including ones which hardly had anything running.
What usage do you see under resources?
Alternatively, you could try running a VD which reboots your HCL every day at for instance 23:59.. If that's an option?
Duplicate. Search the forum before creating the same topic:
