Network Security
Guest David86vm
Hi all,
I was wondering how you guys handle the security of your home lan, with connection of fibaro systems, satel alarm and ip Camera's
Currently I desided to put al my IP Camera's on a seperate VLAN block from going to the internet, and I need a VPN to view remote.
Thinking about how to secure connect the HC2 and my Satel alarm together in one system with IP camera and keeping is secure.
Yes i would like remote acces (can be trough VPN) and push message directly.
My Satel system is currently not yet connected with the home center due I don't how to make a proper secure setup.
How are you guys doing this ?
use router (e.g. Zyxel USG with 2 WAN ports, to have failover as well) with firewall and e.g. objects to allow communication on specific ports between VLANs and from security VLAN to outside world (for e.g. push)
Edited by tinman
Guest David86vm
    I'm using a Edge Router lite with a managed switch.
    @tinman do you isolate ip based traffic between the home center and satel system?
    not satel, but other security system, however for satel will be similar setup, just enable specific objects (based on mac) intercommunication over specific port (7094 i think)
    • 2 months later...
    I use (several) Ubiquity LAN devices, like managed switches, accesspoints and gateways. These are managed by a central controller, which is called a CloudKey, but it is possible to use it for LAN access only (without the need of being forced into the cloud, which I prefer).
    For my IP-cameras I use a separate VLAN, also a separate VLAN for IoT devices. All access to the internet is blocked, even the HC2. The only access to the internet is a Synology (for use of OpenVPN to access the LAN from the internet) and a Raspberry Pi with Node-Red.
    I have just one port opened for accessing my LAN (OpenVPN). Access is firewalled (country/mobile provider IP-range only) and encrypted. Access from outside my LAN can only be done by OpenVPN. When accessed I can access all services like I do on LAN.
    On the LAN, I have enabled encrypted communication as much as possible (HC2 is the real weakest link), enabled monitoring with DPI (Deep Packet Inspection) and active protection by IPS (Intrusion Prevention System/Suricata). Also a set of firewall rules is used to prevent unauthorised (LAN) connections.
    Once in a while a do some penetration testing (OpenVas, Kali etc.), check several sites with the latest information (shodan.io, exploit-db.com [
    ], blog.g0tmi1k.com etc.)
    The keywords are: Segregation, firewalling, encryption, update & backup, monitoring & (re)act. And, of course , ask! ;D
    BTW, I don't have a Satel Alarm...
    Edited by Lambik
    " to "
    Temat został przeniesiony z "
    " do "
    palo alto p220, zone it off in its own vlan with rules.
