FIbaro switch firmware update 3.3
One day ago I received a lot of module firmware update notices for the Fibaro switch
I can upgrade now from 3.2 -> 3.3
Biggest question, what's new ?where are the release notes ?
I see no other mentions of this update or am I missing something.
Hope someone can help me out here.
p.s. I tried posting in the "Modules Update" forum but could not select it.
Edited by Vinisz
spelling
The release notes are in the update notification. if you scroll down you will see the notes.
Edited by fkruis
    Nope, sorry, they are not there.....
    they are view able when you press the update button , just before you agree to the update
    Guest Lode
    Guest chaicka
    Is this only for the 'Double Switch 2'?
    Thank you for sharing. I did not notice because I do not have any updatable modules.
    I'll add this info to one of my all-time-classic-topics:
    Guest Lode
    This was only for Double switch 2 (here at least).
    Edited by Lode
    +1
    Guest chaicka
    Thanks Lode and Thomasn.
    I too am only seeing it for Double Switch 2. Yet to perform the update though.
    I also had this update on 2 devices. Proceeded to update, new FW 3.3. But, coincidence or not, as soon as the update was done, 2 other devices - a fibaro motion sensor and a danfoss RS - went completely dead.  Changed batteries, tried soft reconfig, nothing worked. Ended up force uninstalling them and adding them again. They seem to work ok 24h later.
    Just posted this as i do not believe in coincidences like this. System was up and running smooth for 38 days, on 4.140 . Only intervention i did was to press the update button for  those devices.
    " to "
    Temat został przeniesiony z "
    " do "
    Yes, it's only for Double Switch 2.
    Maybe somebody can explain this problem? Proposed to upgrade 'Double Switch 2' but looks as hang. Should I still wait? How long? HCL 4.160
    Edited by OlegV
    Looks like you haven't hit the three ... on the first one - then scroll to find update
    You're not right :(. I meant "Firmware Update: downloading"
    Guest chaicka
    Managed to find time to update the module's firmware. The update went fine without affecting the power supply to a Mac Mini (required as it runs DHCP, DNS, etc services) throughout the update. I did shut down the other non-essential appliances though.
    All mine refuse to update.  Just say failed every time I try:
    Aha, so here is the reason of mailfunction of both of my Double Switch 2.
    I dont know how to reproduce the issue, but when the light is ON for a while, one of the buttons doesnt work for ~5-10 seconds.
    Tell me how to rollback to v3.2 please?
    " to "
    " do "
    Hello, I am a SmartThings user. Can I have the lastest firmware file in order to update Fiabro 3.2 by myself ? (Lot of bugs in 3.2 like bistable ....)
