ipsofacto 8
com.fibaro.FGRGBW441M
Two installed controlling LED strips. See the response from
for the two different devices.
One has isLight set to TRUE ... one has isLight set to FALSE (first example) but second example is TRUE. Why and how?
WHY? Can this be configured? Both are used on RGBW and clearly lights - programmatically inconvienient as the isLight boolean would be a good filter if this could be corrected. It would also be good if you could set virtual_device to be represented as isLight TRUE
Anyone any ideas?
using the follow query to extract all devices with a light interface to store their state as a "preset" in a room that can be called up by VD or scenes e.g. Morning, Evening, Enteratining, Relaxing. Plan is to incorporate these into "intelligence" but let the user (family) configure what the actual preset is using a VD to query current lights in a room storing this as the preset.
The results of a simple get device API call shows the same module exposing different isLight on query. Both are RGBW driving lights implemented physically as LED strips.
Edited by ipsofacto8 answers to this question
