manuelst 0
hi,
I bought two domux products (zwave plus)) but they do not integrate correctly with fibaro hc2 release 4.120.
subsequence releases integrate dumux sensor ?
- Domux dx1co-z ( sensor monoxide CO) - template id-0260-8005-1000-01-0A--.zip
- Domux dx1cg-z ( sensor gas, CH4) – template id-0260-8003-1000-01-01-- .zip
HC2 does not detect when they are safe or breaked. On interface HC2 I always see "Never Breaked", and so my scenes don't start.
the sensors work correctly because (for example) if i use the command in lua fibaro:getValue(150, "lastBreached") i see 1518214851 that is 02/09/2018 @ 10:20pm (UTC)!!!!
that is the time when i did a test with lighter near the sensor!!!
If the sensor don't have a template it means that I can not have ony information about when it was breaked?
if i use fibaro:get(150, 'alarmlevel') i have always 0 both in normal conditions and when I use the lighter and I trigger the sensor that sounds. Hc2, however, does not detect anything ;-(
what is the correct command in lua to check the status and at this point make a scene
that sends me a popup or email that the sensor has detected monoxide C0?
I attach template for future integrations.
thanks best regards.
please help me!
