kennybroh 0
I installed a Dimmer 2 in a 2-wire location, to control some overhead LEDs. I am reasonably certain I wired it correctly, L is hooked to the line, and the lead at the other end to the load. i tried using several different switches, but all had the same result: the lights could not be turned off with the switch, the LED on the Dimmer 2 is solid green, and does not change when I press and hold the B key, and I cannot include the device into my system.
I am not using a bypass. Would all of those symptoms reflect the need for a bypass, a defective Dimmer 2, or something else? I previously had a two-wire X-10 switch in that box which worked fine, but it will not support leds.
Any ideas would be appreciated.
5 answers to this question
