Hi there,
this Python script extracts the Lua code and the top level definition of each scene to individual files. Should be handy if you ever need to restore scenes
Enjoy.
/jayrock
#pip install requests OR python -m pip install requests
import requests
import json
# HC access data is defined globally
# change as needed
hcl_host = "192.168.0.1"
hcl_user = 'admin'
hcl_password = 'password'
## no user edits below
# get api response from HC
json_scenes = requests.get("http://" + hcl_host + "/api/scenes", auth=(hcl_user, hcl_password))
scenes = json.loads(json_scenes.text)
l = len(scenes)
for i in range(0, l):
    id = scenes['id']
    name = scenes['name']
    print(id, "\t", name)
    json_thisScene = requests.get("http://" + hcl_host + "/api/scenes?id=" + str(id), auth=(hcl_user, hcl_password))
    thisScene = json.loads(json_thisScene.text)
    if (thisScene['name'] != name):
        print("Error")
    else:
        print("ok")
    thisLua = (thisScene['lua'])
    with open(name + '.json', 'w') as outfile:
        json.dump(thisScene, outfile, indent=4, sort_keys=True)
    with open(name + '.lua', 'w') as outfile:
        outfile.write(thisLua)
Edited by jayrock
