Mesh Network reconfig made easy or easier
AutoFrank
If you're like me and you have a a dead spot or two in your zwave network from time to time, then this may help.
Normally I find a Mesh Reconfiguration of the device and  its neighbors can help. The only issue is that this can be time consuming to do this through the UI (Configuration, Zwave network, Mesh Network Configuration) as it requires (two clicks per device) and it can frequently take 5 or even 10 attempts to get the "New neighbor list received" message.
@T.Konopka shared a mesh reconfig command a while back and II just got around to using it and the results look promising.
The following is a very simple scene that take a number of devices and loops through a mesh config 20 times, with an 8 second sleep in between.
Just remember to use the parent / master device ID
You'll see the results in the top message bar
/monthly_2018_02/image.png.5e9b24c6d2df3a45360444fb43c9e988.png" alt="image.png.5e9b24c6d2df3a45360444fb43c9e988.png" />
I have found that in a typical 20 loop cycle, I'll see a lot of fails but a couple of successes and all you need is one
jT.sc.SmplLog is a just a message logger I use so you can comment that out
The scene above could definitely be improved with the use of a tables or other methods but this should help get the idea across
Very handy scene thanks.
I seem to get this error every time i try using it. Am I doing something wrong?
/monthly_2018_02/Capture.JPG.6c6881f925185c7d478682f652b880e6.JPG" alt="Capture.JPG.6c6881f925185c7d478682f652b880e6.JPG" />
