Zipato/Domux/Heiman Gas Sensor: Notification not work!
Good Morning,
I have bought a Zipato HS1CG-Z (Gas Sensor), that i think is branded also with Domux & Heiman.
Link:
The device inclusion working well, the HC2 identify the device as "Motion Sensor". (Device without template)
Trying to test it pressing the "test" buttons nothink happend. (Device never breached)
 have also checked in LUA, the following values: "alarmLevel, alarmType, lastBreached" ...but the output is always "0".
Any idea / troubleshooting to suggest?
Thanks in advance
Regards
Gianluca
Edited by Gianluca S.
5 answers to this question
    Nobody?
    I have setted the sensor as "door sensor" and tested in LUA....
    %% properties
    %% events
    %% globals
    local sensorID        = 190
    local testa0=fibaro:getValue(sensorID, "alarmLevel");
    print(testa0);
    local testa1=fibaro:getValue(sensorID, "alarmType");
    print(testa1);
    local testa2=fibaro:getValue(sensorID, "lastBreached");
    print(testa2);
    local testa3=fibaro:getValue(sensorID, "armTimeTimestamp");
    print(testa3);
    The output is:
    [DEBUG] 10:38:53: 0
    [DEBUG] 10:38:53: 0
    [DEBUG] 10:38:53: 0
    [DEBUG] 10:38:53: 0
    Any idea or suggestion to continue the troubleshooting?
    Thanks in advance
    I have found this schema:
    /monthly_2018_02/image.png.124063a8b739696c8842e931b11c6c79.png" alt="image.png.124063a8b739696c8842e931b11c6c79.png" />
    Maybe can i add parameter?
    How to proceed?
    news ? fibaro support ?
    news? fibaro support...........
    ciao, io non ho ancora aggiornato e sono rimasto alla 4.120. Ma ho letto che dalla 4.520 hanno aggiunto il supporto per Heimann e quindi anche per Domux....me lo confermi ?
    ciao Gianluca io non ho ancora aggiornato e sono rimasto alla 4.120. Ma ho letto che dalla 4.520 hanno aggiunto il supporto per Heimann e quindi anche per Domux....me lo confermi ?
