After update for beta version, my hc freeze and motion sensor is no connected in conditions.
Does not appear like a motion sensor and notifications are always off.
Can i rollback? how?
thank you
Hi
I have driven 4.161b for a week now without any problems.
Have you tried a restart.
Have you tried to retrieve auto backup.
Try this before you rollback.
Rollback:
Note, new location of file.
Edited by hTiger1
    Hi Tiger1,
    In first place let me thank you for the help.
    I have restarted the unit and put the autobackup with no result.
    the backup only apply the changes not the firmware, correct?
    Can i use the this file? http://updatehcl.fibaro.com/4.160/patch.tar.gz and apply it from "repair from file" option?
    Can you help with the other post to? how to connect tp-link nc450 ipcam on unit.
    i will give you feedback from firmware update
    thank you
    Hi
    That's right, about backup.
    Which FW. have you upgraded from?
    I think it's best to go back to the FW. you had before.
    Then you may need to customize the name of the FW file.
    There are some guys out there, like much more about ip cam.
    Hello!
    Thank you for the tips.
    I have upragded from the last one, the unit is brand new, 1 month.
    I have reset the unit, update firmware again and reconfigured and now it is almost OK :)
    I´m not able to arm/disarm the alarm. My motion sensor is working and send me notifications but how can i arm or disarm the alarm. i don´t mind that he is always detecting, but i want the alerts only when is armed.
    arm or disarm the sensor in his buton does not do nothing. where do i have to configure it?
    I will post again because the ip tp-link.
    thank you
    Hi
    Maybe you can use this.
