triple click (id 15) s1 not added
I have a problem with triple click on s1.
I have a HCL and dimmer 2 with double momentary switch.
After i push all possibilities on the switch, everything is added except triple click for s1 (number 15).
So, 22,23,24,25,26,12,13,14,16 is added, but 15 is not.
How can i fix this?
4 answers to this question
Buy a dimmer 1, dimmer 2 sadly doesn't support trippel click. I had to learn the hard way aswell...
    Are you sure?
    Because it works for s2 (25), but not s1....
    best,
    Twan
    Goede avond Twan,
    I asked this on the forum here a long time ago because i couldn't get it to work and got a reply that dimmer 2 doesn't support triple click.
    ok, thanx.
    This seems to be the case.
    I think good to add, that on s2 it does work.
    Maybe it has something to do with the fact that you use triple click to add or remove the dimmer to the z-wave network.
