TP-LINK Nc450
Hello!
I am looking for some help.
I bought a fibaro hc lite and i whant to add my ip cam tp-link nc450 to the system.
How can i do it? it is possible? For you what are the "best", more simple and trusted ipcam to connect? I have tried as other model whit no results. The firmeware has any tp-link model.
Thank you
6 answers to this question
I responded to your private message.
But, I will post a link to the guide here as well
I was able to connect TP-link NC-450.
Password: !! Your passwords base64 encoded version !!
You need to change the <ip_address> section with the local IP address of your Camera
You can also change your password to base64 format via this website
anyway recently something changed and I'm not able to see the picture form camera on the fibaro browser in the computer but I can see it only in the mobile app.(in the phone). Can someone help to reslove that?
/monthly_2019_01/image.png.6b8646186f452372e9236e0acbb3762b.png" alt="image.png.6b8646186f452372e9236e0acbb3762b.png" />
    Hello!
    What model of cam did you choose on general settings?
    I never had my cam working.
    It is really necessary to change the password?
    When you say "ou need to change the <ip_address> section with the local IP address of your Camera " what you mean? can send a print?
    thank you
    You have to choose : other model
    /monthly_2019_01/image.png.ccabd94f508c50bf5ec25fa773f99285.png" alt="image.png.ccabd94f508c50bf5ec25fa773f99285.png" />
    then you have to fill manually all fields as shown in my previous post
    YOu can leave your default user and password but remember to convert password to base64 format before you enter it to fibaro password field
    you need to know what is you cam IP:
    in my case it is 192.168.1.100. You have to replace it using yours.
    IP adress must be followed by port 8080
    I hope it is clear enough
    Dear @markymm I tried you solution, but infortunately it doesnt work for me. I have the TP link NC250, could that be the issue? Any other suggestions are welcome ofcourse
    after few software updates it stopped to work.... sorry
