add device button - no reaction
here is log after 5 min.
notice: HC2 just restarted!
[10:46:56] Home Center in learning mode
[10:46:56] Learning mode error. Try again.
[10:46:56] Adding devices complete
after 5 mins device have added but with issues
FIBEFGK-107
    after remove
    reboot
    add device process stuck here
    15min in progress
    Here is a topic in which I post several ideas regarding inclusion weirdness.
    But to be honest... I follow your posts closely and I think you have either (a) rather strange issues with your HC (b) A network that is too busy or has routing issues, possibly a soure of interference or devices that send too much or random data.
    But I'd start here anyway (Occam's razor)
    [17:53:05] Home Center in learning mode
    [17:53:08] Device was deleted successfully
    [17:53:33] Home Center in learning mode
    [17:53:46] Device was deleted successfully
    [17:53:46] Slave Device Detected
    [17:53:56] Home Center in learning mode
    [17:53:58] Device was deleted successfully
    [17:54:00] Slave Device Detected
    [17:54:00] Removing devices finished
    [17:54:56] Home Center in learning mode
    [17:55:00] Device added
    [17:55:22] Adding devices complete
    [17:58:22] ERROR: Device nodeID = 148 does not exist in database
    try #5
    stuck again
    [18:11:46] Home Center in learning mode
    [18:11:56] Device added
    [18:12:17] Adding devices complete
    [18:12:18] ID 4: Received association report from group 1
    [18:12:19] ID 4: Received association report from group 1
    [18:12:21] ID 4: Received association report from group 3
    [18:12:22] ID 4: Received association report from group 3
    [18:17:05] ERROR: Device nodeID = 149 does not exist in database
