VD pressButton with HTTP
eva
I tried a lot of links like these and got only {} response.
Please can anyone write how to trigger VD button with http?
VD with ID : 15
Button ID : Button11
+also tried with postman basic auth didnt work.
7 answers to this question
1. On VD HCL you need use structure of request like this examples in button :
ex1 (change label)
GET /api/callAction?deviceID=62&name=setProperty&arg1=ui.Label1.value&arg2=TEST HTTP/1.1
Host: 127.0.0.1
Authorization: Basic cGR1cmJhamxvQGl0LXNlY3VyDSsdsfe99999FxcTI=
ex2 (the ID of button is position numer of element in VD including all labels, buttons before)
GET /api/callAction?deviceID=213&name=pressButton&arg1=1 HTTP/1.1
Host: 127.0.0.1
the Authorization Basic string is your user name (email) and password coded by Base64
You need write in IP zone of VD the: 127.0.0.1 and i PORT zone: 11111
2. If you call from webbrowser or any another device / program you use structure like this:
http://adminemail:[email protected]:11111/api/callAction?deviceID=213&name=pressButton&arg1=1
ex linux shell
HC_command='http://192.168.1.X:11111/api/callAction?deviceID=213&name=pressButton&arg1=1'
/usr/bin/curl --user [email protected]:password $HC_command
Edited by drboss
@drboss so if I'm using a VD like VSL that has many different buttons with off and on etc, where would i find the ID of the button that I'd like to use for a "virtual push" in the callAction? I included an image for illustration purposes.
23 minutes ago, drboss said:
Id of this is 9
Textlabel do also count as an ID. So simply counting the buttons is not correct.
@matt1981
  • You could open up
      and search for the device ID of your VD.  The VD ID could be easily found out if you do a mouseover of the little "edit-button" in your fibaro webinterface. Bottm left or right, pending which browser you use (in IE its left) you would see something like ?id=xx - this would tell you which ID you have to search for.
  • Other option is to use HC2 Toolkit of this forum made by Krikroff
Yes I wrote this in my text, count labels and buttons. But one time count label nam with value. For buttons count all buttons not group as one.
  • @drboss @bl5cky Thank you
    Worked:
    http://admin:[email protected]/api/callAction?deviceID=23&name=pressButton&arg1=1 (ON)
    http://admin:[email protected]/api/callAction?deviceID=23&name=pressButton&arg1=2 (OFF)
    Find arg1 ID of button from http://192.168.0.31/api/devices (dont use element's name "ButtonXX")
    On the main "Devices" screen VD have a single button and it toggles on to off but doesnt toggles off to on?
    Details:
    How to change VD icon to "on" ?
    Main "Devices" screen shows VD like this:
    When i press the button it sends OFF and new icon is:
    But when i press button again it doesnt change OFF icon to ON icon and also didnt send ON command from HTTP.
    This works normal when i press on - icon is on and sends HTTP command ON.
    When i press off - icon is off and sends HTTP command OFF.
    If I understand well and depends of limitation of HCL you need use second REST command:
    /api/callAction?deviceID=62&name=setProperty&arg1=ui.Label1.value&arg2=label%20text
    or use the auto scene for change label like this:
    /monthly_2018_03/image.png.5fa247cab6650d4a1100e2967384e624.png" alt="image.png.5fa247cab6650d4a1100e2967384e624.png" />
