I'm trying to upgrade HCL from 4.160 to 4.161beta. System tells me it's updating... But, it's in this state for 6 hours now.... I'm afraid nothing is happening and the system froze. And now?
Update: I tried accessing my HCL by reloading ipaddress. I get error 404. So system is completely dead.
Has you tried to refresh?
    @EirikT., as you can see in my update on this issue refresh or reload gives 404 error. System is completely dead after starting this update! It looks like there's no system at all anymore. Tried to access docs folder on my HCL, also came back with 404...
    looks like pretty serious bug to me if updating causes total crash of the system.... I'm trying to restore previous version, so far no luck :-(
    Take out the power plug, press + and hold it, then you plug in the power plug, leds are now flickering different from normal. Don´t hold the + for more than 10 sec. Now you have a more avanced meny.
    I have the same issue. My HCL won't update either. Tried three times already.
    I always end up with 404 error and have to reboot (take out the power and plug it back in).
    This would be funny if it wasn't that sad.... On every update i'm hoping for a stable system at last. Also on every update i'm afraid of the new created bugs waiting for me.... It looks like the bugs won at last, they're now so big with so many that updating the system is not longer possible.....
    horrible
    Hello @Reintjan!
    I've seen that you contacted our support. They will do the upgrade manually.
    Hello guys!
    Good news!
    It should be possible to update your HCL normally now.
    So just please try to update it again ; )
    @I.Srodka, i tried updating again and can confirm it works now. My HCL is now running 4.161b
