pascald 5
I have tried to contact fibaro regarding a recent installation of the Intercom. No response through any channel. My conclusion after 2 weeks: the product is totally UNUSABLE.
Issues:
1. You cannot take a call on iOS devices as login is not working most of the time hence you cannot intercept a call. Login should be immediate which is not the case.
The Login process is really bad: sometimes it works as local, sometimes as remote, sometimes not at all. And when you need to take a call, the not at all option is the most frequent. Additionally when you have a login issue, you would have to quit the app to hope being able to login again.
2. It is too slow to show the video hence you never get the video of the people ringing
3. When you manage to respond on one device by intercepting the alert (audio mostly as the video almost never works) it keeps ringing on others
4. The iPhone app is poorly designed and not suitable for iPads which are used in horizontal mode (the most obvious mode) as rotation is not automatic and menus are not working in that mode
5. Login is regularly lost even for iOS terminals that stay permanently in one place (an iPad in the kitchen, wired)
6. It has crashed twice in a week, without reason
7. Voice mail feature is poorly designed and caller has no idea what to do (no message heard)
And additionally, no support provided. Fibaro doesn't respond to cases, neither to forums, etc.
The product is really bad and should maybe be abandoned by Fibaro that should better stick to more simple products and fire the engineers responsible for the Intercom.
I expect an intercom to:
- work 100% of the time on in-home terminals without login issues or lost streams
- provide a coherent and easy experience on these in-home terminals, analogous to what classical intercoms do
- be synchronised among terminals, ie when one terminal takes a call, the others would stop ringing within a second
- provide a systematic alert on 4G to terminals used when roaming outside of the home, video should work at least 90% of the time, audio 100%
this is the basis for an intercom. if that is not possible, drop it!
25 answers to this question
