marbe 23
still Heat controller doesn't work, still every morning is very cold at my room.
I know we are waiting for new firmware, but our outside temperatures are now very low.
Therefore I wrote code for virtual device for temporary resolving this issue.
It:
- check actual temperature at room and compare it with setpoint for room
- if the temperature is lower as 0.4C compared with setpoint , then it sets Heat controller to MAX mode
- after reaching setpoint, sets it back to scheduler mode
Its only temporary solution, therefore it not aspect all situations.
It work only for 1 room, for more rooms with heat controller is necessary add it to all.
I hope it helps now.
Martin
