Greenwave Powernode 6
I've the Greenwave Powernode 6, but after power loss every outlet turns to ON, how can I set it so it will remember last state or set all to OFF?
This is some parameters that I've seen on the internet, but I don't know if they are valid.
parameter 0: Power change required to send a notification, in % from 1 to 100, default 10
parameter 1: Keep alive time, in minutes from 1 to 255, default 2
parameter 2: Color wheel selection, read only
parameter 3: State after power loss, 0 = all off, 1 = remember last state, 2 = all on, default 2
parameter 4: Led for network error, 0 = disable, 1 = enable, default 0
6 answers to this question
hi,
these parameters only work  with greenwave powernode firmware 4.28.  As far i know it is not possibly to upgrade the firmware.
Edited by fkruis
    I hate when you can't upgrade the firmware in your devices ]:->
    hi there,
    I also have 2 of the powernodes running version 4.21. I can confirm both parameters 3 and 4 are not working.
    We really would need an alternate product.
    Unfortunately aeotec offers their power strip only in US
    Maybe if enough of us ask their support via email they consider releasing it for EU market too?
    BR - kro
    uhmm, same firmware 4.21.. what to do?
    Anyone know why its not possible to upgrade the firmware?
    I contacted their support. here is the answer.
    Quote
    Thank you for your inquiry.  I regret to inform you that the PowerNode FW is not field upgradeable.  It is also End of Life and no longer supported by Greenwave Systems.  We stopped manufacturing the PowerNodes a few years ago so we could focus on other areas of our business, specifically software development.
    So: no field upgrade possible. EOL
