Hi, I am trying to start a fibaro wall plug from a VD button.
I have 4 buttons and would like the first buttons to start the fibaro wall plug for 15min and turn off.
Second button starts the fibaro wall plug for 20min and turn off.
Third button starts the fibaro wall plug for 25min and turns off.
Forth buttons starts the fibaro wall plug for 30min and turns off.
Could someone help me in doing this? Any help is much appreciated.
Edited by Helm
In Hc2
Button1      fibaro:call(5,”turnOn”)                    —  5 = wallplug id
                    fibaro:sleep(900000)                     — time in  miliseconds 15 min
                    fibaro:call(5, “turnOff”)
Button2      fibaro:call(5,”turnOn”)
                     fibaro:sleep(1200000)
                     fibaro:call(5,”turnOff”)
Edited by Jamie mccrostie
    20 hours ago, Jamie mccrostie said:
    In Hc2
     Each time the Buttons are pressed the sleep function starts again. Do you think it is possible to add a label and display a countdown in the VD and each time the button is pressed, the countdown starts from the beginning?
    Edited by Helm
    @HelmTry this VD attached you have to change your device ids.
    There is a 60sec odd delay before you can restart after resetting timer.
    You may be able to adapt it further to suit. Once time is set you can also start with main button of VD.
    @Jamie mccrostie Thanks, This helps alot.
