how to call other system from lua
Hi
Can someone point me to right direction
I want to send this command to my other controller from Fibaro
world
How to put that command to my scene?
thanks for advance
Edited by Markoe
4 answers to this question
For scene you need write it in LUA like this
for VD you have 2 possibility:
in LUA:
(very simple ex,  in VD IP zone write IP address of remote server and in PORT remote port 3480)
in TEXT (in VD IP zone write IP address of remote server and in PORT remote port 3480):
    Yes , succes .
    17 hours ago, drboss said:
    error = function(err) print('error = ' .. err) end end,
    I did replace with "error = function(err) print('error = ' .. err) end, " . After that it did work.
    Thank you for your help @drboss.  This was way byond me present skills :-)
    Was it so that global lua fuctions are not allowed at Fibaro. I would love to make this as a global function so I can use it in multible scenes and not copying the same code to all needed schenes.
    it's not possible. we asking from FIBARO this functionality more than 2 years
    if I not need return parameters from function and I use the same code (functionality) in many scenes and VD I write it in separate scenes and call it with arguments.
    Ex. for call universal scene for send Telegram message
    But exist two way method to call scene with arguments and return result. The best example is GEA v6 script from  forum.domotique-fibaro.fr. Author use global variable to return results with time stamp. Another method (I test my very alfa code) is use possibility to write results as debug message of another scene.
