jeyb 0
I have impression that Fibaro ignores most of devices from other manufactures:
- look to the structure of this forum - non Fibaro devices are in a different sections
- look the history of updates of hc2 and hcl - past few updates are focused on fibaro heat controller - focus is on their devices
- support cannot give you any dates for fixes - they are saying the same stories that they cannot influence on programmers schedule - does support represent different company?
- support says that most of non fibaro devices are small market in the same time not having their solution - in this context danalock , keypads , strike locks solutions are not important
- I've offered even sending devices for test or template preparation- no reply at all
- most of non fibaro devices which don't have template.
In my opinion it is too risky to buy Fibaro controller if non Fibaro items are necessary in the system because probably they will never be supported.
Forget compabilty guides - FIBARO HC2 and HCK is ONLY for Fibaro devices (limited offer) - You will be ignored by support (promises about next releases , asking on forums if is there any solution, etc).
Sad conclusion:
Fibaro is for Fibaro DOT.
4 answers to this question
