When changing block scenes I miss the option to remove an action above the last added.
Example: I want to remove "Devices Group" = Turn on, but keep all other actions. To do that I now have to press the minus sign at the end multiple times and then redo all actions that I want to keep.
Idea: Add -/+ sign before every "and"
/monthly_2018_03/image.png.36b5903e5b133997097ee670db985b8b.png" alt="image.png.36b5903e5b133997097ee670db985b8b.png" />
good point +1
Hi
One way to solve this could be opening LUA on HCL. We know that HCL can drive lua, and HCL also runs better and maybe more stable with LUA.
---- Practice, only after you drive HC2, then my answer is not relevant.
Edited by hTiger1
    I thought HCL didn't support LUA? Only HC2?
    I have a HC2 and can use the LUA-workaround that you mention (good idea by the way), but the block scenes are all about simplicity and I think many users would prefer a solution for the block scenes.
    Hi
    I would also like to have such a feature as you suggest.
    No HCL can not run LUA, as it is now.
    Fibaro made a mistake, a FW around 4.070 we could run lua on HCL, I had converted all my scenes (about 40) to LUA, and I thought it run better in LUA.
