@Matúš Noga , please stop spamming.
You have 4.170 installed according to this post
This is a thread for 4.160.
If the gateway in unresponsive you should contact our Support like @Al Yakuzo did. Our engineers will help you.
  • 2 years later...
My HCL Lite is still on version 4.58 only because my device freezed each time I tried to install an update. The problem and symptoms are exactly the same as described already above in this thread by Franz@ on 9/3/2018.
Unfortunately, I can't find the answer or solution anywhere in the earlier discussions/questions/remarks.....
So, what do I need to do in order to be able to update my device ?
The only solution I have right now is buying another Z-wave server (and it will not be a Fibaro this time :-) ...).
Thanks in advance for your useful advice !
