roller shutter LUX/move control
Hi!
I am a beginner in LUA and this is one of my first approaches.
I would like to have my roller shutters opened when move is detected and some other conditions are met.
Currently I get too many instances in my scene all the time and it does really what IT wants - usually opens all the rollers up whenever movement is detected and all conditions are met.
It doesnt wait between tries.
I would like this scene to be run every 5 minutes and not 30 seconds as it runs default.
Now, HC2 doesnt care about my fibaro:sleep - it just opens rollers constantly and after few minutes I get information about exceeded instances.
How to make this scene work every 5 minutes?
Do you know any other scene that does it written by someone with better LUA skills than mine?
It shouldn't be difficult ;-)
POZ_ROL are my rollers.
334,238 are my motion sensors
336 is LUX sensor
%% properties
336 value
157 value
159 value
161 value
181 value
%% weather
Temperature
%% events
%% globals
TimeofDay
local POZ_ROL5 = tonumber(fibaro:getValue(157,"value"))
local POZ_ROL6 = tonumber(fibaro:getValue(159,"value"))
local POZ_ROL7 = tonumber(fibaro:getValue(161,"value"))
local POZ_ROLK = tonumber(fibaro:getValue(181,"value"))
local LUX = tonumber(fibaro:getValue(336,"value"))
if (
-- (api.get('/weather')['WeatherCondition'] ~= "cloudy" and api.get('/weather')['WeatherCondition'] ~= "storm" )
-- and
 (( fibaro:getGlobalValue("TimeofDay") == "Morning"  or  fibaro:getGlobalValue("TimeofDay") == "Afternoon" ))
and
 (( tonumber(fibaro:getValue(157, "value")) < 99  or  tonumber(fibaro:getValue(159, "value")) < 99  or  tonumber(fibaro:getValue(161, "value")) < 99  or  tonumber(fibaro:getValue(181, "value")) < 99 ))
and
  ( tonumber(api.get('/weather')['Temperature']) <= tonumber(20) )
and
( ( tonumber(fibaro:getValue(334, "value")) > 0 ) or ( tonumber(fibaro:getValue(238, "value")) > 0 ) )
and
    (LUX < 250)
  or
startSource["type"] == "automatic"
      then
    fibaro:call(157, "setValue", POZ_ROL5+25);
    fibaro:call(159, "setValue", POZ_ROL6+25);
    fibaro:call(161, "setValue", POZ_ROL7+25);
    fibaro:call(181, "setValue", POZ_ROLK+25);
    fibaro:debug(POZ_ROL5)
    fibaro:debug(POZ_ROL6)
    fibaro:debug(POZ_ROL7)
    fibaro:debug(POZ_ROLK)
    fibaro:debug(LUX)
    fibaro:sleep(300000)
  else
   fibaro:debug("Warunki niespelnione")
   print "TimeofDay:"fibaro:debug(fibaro:getGlobalValue("TimeofDay"))
   print "Temperatura:"fibaro:debug( (api.get('/weather')['Temperature'] ))
   print "Rolety:"
   print "Światło [LUX]:"fibaro:debug(LUX)
