rbhun 0
Hi
sorry for the stupid title, I dont have any better right now
tl/dr: do a trigger keep rerunning/starting a new instance of a scene?
long version:
I want to create a scene where my bathroom fan turns on if humidity sensor is over 70%, then turn off.
If I do this:
if
( tonumber(fibaro:getValue(298, "value")) > 70 )
then
fibaro:call(413, "turnOn");
fibaro:debug('WC humidity over 70. Turning fan on.');
fibaro:sleep(120000);
fibaro:call(413, "turnOff");
fibaro:debug('WC humidity under 70. Turning fan off.');
will the HC2 check for the humidity every second or so? and if yes, will it start a new instance of the same scene, or somehow lenghten this?
or shall I do this?
if
then
else
but in this case, will the fan turn off is the humidity falls under 70?
I cannot find a good description of triggers, and it seems so important...
thanks in advance
11 answers to this question
