TomC 0
Hi All,
I've just got my HC2 out after it's been sitting in a box after moving about 6 months ago to start putting into new house and I can't connect to it any more. I can get into recovery mode and have successfully restored it around 3 times now. It then says that it is restarting and the lights start to flash across the front but when I put in the IP address to try and connect after that it won't do anything. Pinging that IP address gets no reply and the Fibaro finder tool can't find anything. When I power it down and go into recovery mode again Fibaro finder finds it and it can be pinged. IP address has stayed the same and I have it plugged directly into my laptop with a static IP set on my laptop to connect to it.
Has anyone else run into this problem before?
Thanks, Tom
