Hi all
I've Onkyo  TX-NR636 - HC2 found this and add it. But only what I can do is to turn it on/off. Other buttons doesn't work. Did I anything wrong?
thanks Zdeněk
12 answers to this question
Good evening @zdenek, I have the very same receiver.
This is how you get it to work:
Step 1: delete the official plugin.
Step 2: download and install the VD from here :
Step 3: Enjoy!
Jim
    @jimicrexcelent, thanks. Works almost perfectly. I Cau use volume slider which is for me the most importtant. But:
    - even reciever is off, it shows in app volume on postion 29 (probably the last position)
    - after turning On (via remote control) the slider doesn't respect the actual volume on reciever itself. I've to change volume via Fibaro and than I get the same values in Fibaro and on Reciever
    - via this plugin I'm not able to turn on and off the reciever
    do I need to any modification of the code to get it work?
    thanks
    Edited by zdenek
    Good morning. Sometimes I need to restart the receiver itself to get the volume to work. May ones every 2 or 3 months
    @jimicr good morning. Restart? I do every day to tornu it on/off via RC, cause via Fibaro it doesn't work. This is what u call "restart"? For u it works? For me it worked just with official plugin.
    Just unplug the receiver
    @jimicr done. But on/off via Fibaro still doesn't work (IP is right - after turning On I can switch inputs...)
    I don't use the one off button I use my harmony for that. I really only use the slider
    ah, I see. OK, thanks anyway
    Hi @zdenek which ONKYO model do you use? I have somehow fine-tuned several ONKYO vds from the forum - maybe you could check that.
    Best regards,
    Andrzej Browarski
    ahi @AndrewB82 I've TX-NRN636
    thabks
    Gents,
    could you tell me which ports are you using to operate your Onkyo receivers via LAN?
    I'm using the Home Center 3 and trying to run RZ50 from it, but default port 6000 does not work.. Wondering if this is the port problem or whole FQA issue..
    Thanks for help.
