Single or double Switch?
Can I use a second physical button on a Fibaro Single Switch 2 to control a Fibaro Dimmer 2 (only on/off i guess) installed elsewhere? Or do I need to get a Fibaro Double Switch 2?
Edit: Like this (see picture)?
Edited by Spindel
5 answers to this question
You need a double switch. But you can also by a nodon switch for controlling another switch.
    What's a nodon switch?
    A nodon is a wall switch to start scenes. You can switch on or off lights.
    Ok, thanks.
    So in the picture on my first post both buttons trigger the lamp?
    Yes that is right.
