Chris84 0
I just got a Fibaro Heat controller with a zway controller/(Razberry). I have read here that I can not update the firmware in this setting.
My The Heat is running Firmware 4.0. Nobody I know has a HC 2/HCL to update my Heat controller.
The Interview process for The Heat fails, but I can use setpoint, and (sadly) this combined with the good userinterface makes it still the best Heat controller around for z-wave so far.
So my question here, what can you recommend me to do:
Is the firmware 4.0 already good enough?
or should I send The Heat in to the shop for an update to 4.3?
or is it not worth it because more firmware updates are on the way?
5 answers to this question
