Label full size feature in VD for website view
KanaChan06
I put this post here because no one seems to have seen it and in the last version there is no update on this problem.
So I maybe should ask this as a new feature of the website to be able to show the VD as in its configuration view.
The Label field is half size in browser:
Because it is composed by two columns:
When I click on on the virtual device configuration, I have the full size of the Label:
And the HTML code is:
We can see it is not the same code for the two displays (even if this one has also the two columns).
Is it possible to have the same Label full size in the normal view?
Thanks in advance.
Kana.
