Max. running instances
Hi.
I have defined scene that closes the light in the room when there is no one over 20 minutes( I use a motion sensor)
Unfortunately I get a message about the Max. running instances...........
Can anyone post an example With scene That does not receive an error message
turn the block scene into a lua code and add the following.
if fibaro:countScene()>1
then
fibaro:abort()
I think this is the easiest way.
I do have the small code above in my scenes and have increased the max scene to 2 or 3 instances.
Still I do receive these errors from time to time... (quite often actually)
