Hi!
after update, I can see a new error
[DEBUG] 13:05:42: Scene started... [DEBUG] 13:11:19: [1;31m2018-03-25 13:11:19.023551 [ error] timer handler failed with error
Hey, Fibaro, what is it? the similar error I was seen some weeks ago on Polish forum...
thnak you!
14 answers to this question
On ‎6‎/‎18‎/‎2018 at 9:04 AM, 10der said:
 My IMHO root issue in implementing and combination setTimeout function + net.HTTPClient.
no, it does have something to do with nil values, you have to check results before formating/using them, that line of code mak no sense:
it should be
Yes, error message is bit strange, but it's just because it gets killed middle of time
    is anybody home? :)
    Hello  @10der
    Yesterday 27/04/2018 for the first time since 2 years I have this error.
    [DEBUG] 19:26:00: [1;31m2018-04-27 19:26:00.248397 [ error] timer handler failed with error
    Last update FirmWare 4.170    Le 25/03/2018
    Edited by henri-allauch
    Hey @10der
    @henri-allauch
    Did you guys ever find out  anymore about this error? Appeared on a main event scene today which has worked perfectly since xmas.
    thanks
    Edited by Jamie mccrostie
    I can reproduce it.
    this script dead after 39- 60 sec after start with this error. My IMHO root issue in implementing and combination setTimeout function + net.HTTPClient.
    Edited by 10der
    Hmmm the same scene i have running on 2x HC2s
    one has error one not
    Scene has run since xmas no problem
    ¯\_(ツ)_/¯
    27 minutes ago, 10der said:
    ¯\_(ツ)_/¯
    Is that Klingon?
    Ahrrr Shrug :-D
    2 hours ago, Jamie mccrostie said:
    Is that Klingon?
    Ahrrr Shrug :-D
    Yes, cap. Worf.
    Mysteries
    11 minutes ago, henri-allauch said:
    No I did not change anything, and the error is no longer apparent !!!!
    heisenbug. it is difficult to recall and localize this error because it is not permanent and occurs from time to time.
    On 3/25/2018 at 3:40 PM, 10der said:
    Hi!
    thnak you!
    Saw this error several times during last few weeks and have asked about it fibaro's support
    Here is support reply
    This error can be related to one of “services” in the system (this depth in the system) or RAM usage (your HC2 get temporary out of available RAM memory)
    If issue appears again we will investigate.
    Have a nice day.
    Edited by cag014
    After several tries I came to conclusion that this error indicates that there is a real error in the code. The problem that the system somehow unable to identify and provide correct description of the error and shows generic error
      [1;31m2018-04-27 19:26:00.248397 [ error] timer handler failed with error.
    In all cases the problem was that some variable value turned to  "nil" during code execution and  this generates this generic error. That's why this error appears time to time.
    So please add more debug information at your code to catch the problem.
    Going forward I hope Fibaro team will fix this issue and will provide correct error description...
    Edited by cag014
    1 hour ago, tinman said:
    no, it does have something to do with nil values, you have to check results before formatting/using them, that line of code make no sense:
    You're absolutely correct, but I expect to receive correct error information and not some generic note that doesn't help to identify the problem.
