Plug reporting overcurrent on washing machine
I recently bought a new wall plug to attach to my washing machine.
However, I have had multiple times where this wall plug shuts down with an "overcurrent" message in the UI.
When I replace the wall plug with another one the problem goes away.
Is this a known issue?
Version = 3.2.
Thanks in advance!
KR,
Kristof
What is parameter 70 set to?
/monthly_2018_03/Capture.PNG.127b47536fa8fb0c5b722e0645145f25.PNG" alt="Capture.PNG.127b47536fa8fb0c5b722e0645145f25.PNG" />
(Sorry Kristof, no answer here) I have the same problem on 2 new wall-plugs with washing machine and dryer connected (both on their own power group and own wall plug).
I cannot find a parameter 70. The parameters are going to number 50.
In energy panel I also see a spike exceeding 3KW, when it stops working but that should not be correct.
I am going to test some older wall-plugs and let know if it than works.
