Qubino 0-10V dimmer compatibility
I'm planning on purchasing some Qubino 0-10v flush dimmers and setting them up with the Fibaro HC2. I just wanted to ask whether anyone has any experience with these modules with HC2 and if there are any issues I should be aware of?
Thanks!
Hi Prankit,
Yes, we have tested it with FIBARO HC. It works.
Just need to be careful when doing the inclusion.
Better to let it auto include after 1st power on.
Thanks!
I have problems with HC3 and Qubino dimmer 0-10 volts. When the mains power is off and then on HC3 loses control over the dimmer. The only solution is to remove and add it again...to configure again, to configure the scenes again....
The same happens with every firmware update of HC3.
Now I am looking for a solution for back up power of every dimmer as the HC3 is backed up. It might be needed to stop updating the HC3 as I lose half day each time.
