Hello, I set up a qubino light-type module, and it was working correctly. By mistake I changed the type for alarm-arming and the module disappeared. I checked the alarm panel and it is not. However in the android application the module is there.
I would like to have the lighting module again, but I can not access the module using the HC2 interface. How can I solve it?
Thank you,
Hi @GreenUser ,
Have you tried removing and adding the device once again?
