[Solved] LUA - need some help capturing part of a string
Hey folks,
I have challenges capturing part of a string (i.e. via string.match and a regular expression). I have spent quite a few hours testing different regular expressions, but so far to no avail. It's probably a blind spot and so I thought, rather than spending more hours muddying on,  I'd come here to ask for some help as you may be more experienced fixing this?
My string is a URL:
The string value that I would need to capture is located in between /devices/ and /abilities/ (so the part that reads
 ) This is not a fixed length item.
It would be great if you could take a look at this and offer some advise!
Many thanks in advance.
Cheers,
Barlow
Edited by Barlow
it is, use
then after device to next "/" you will get always your string
    Hi A. Thank you for coming to the rescue for me!
    This works great. Two birds in one stone, as I can now assist a troubled user of one of my VD's that will benefit from this fix :-)
    Cheers,
    Barlow
