Guest sk8er000
PROBLEM SOLVED!
The HC2 doesn't update the scenes right for the new scenes that are in sections that still have the rights, so the link used was trying to start a scene without the right to see the scene
Hello,I use the http API very often to make some custom scenery using android devices or voice assistants.Unfortunately the HTTP API command does not work anymore for new scenes, but I'm sure that both the scene and the command are correct.The only thing that changes is the SCENE ID.For example:The scene with the SCENE ID 61 works on my HC2 with the following command : http://<LOGIN>:<PASS>@<IP>/api/sceneControl?id=61&action=startif I make a new scene equal to the scene with ID 61 I have 2 identical scenes with a different SCENE ID (for example ID 369). If I try to start this new scene using the following command the scene does not start: http://<LOGIN>:<PASS>@<IP>/api/sceneControl?id=368&action=startboth the scenes are working from the web interface and from mobile interface but only the first is working with the HTTP API, is there a way to fix this problem?Thank you in advanceEDITI've used a Postman to see what each link reports, the working one reports "202 Accepted" the non working one reports "404 Not found" but both scenes existPlease login or register to see this attachment.
Edited by sk8er000Solved
