[SOLVED]Single Switch .....do I need the wall switch ?
I have lamp in my corridor that I only want to control only by my HCL.  My question is; do I really need the switch i have been using up till today?  If yes; why ?
I really do appreciate your answers.
I intend to only use Single Switch and the motion sensor .
4 answers to this question
No, you do not need any extra (old) switch. It's great to control the lighting with just a Motion sensor and a Single Switch.
I have done so in my garage where the power switch is sitting at the "wrong" door.
    Thanks  @RH_Dreambox.  Do I need to connect anything over S1/S2 ?
    No, you do not need to use S1 or S2 if you do not need it. Leave them as they are. You can use them at a later time if you see that you need to control the Switch with other features.
    Thank you 4 you great help here @RH_Dreambox.  I am really happy for it.  Thanks :)
