Net.FHttp with space in GET command
                I need your advise - I trying to uset Net.FHttp and the GET command to activate motion alarm on my wanscam camera, unfortunately, the command contains SPACE and I cant get it working - any idea pls ?
http://192.168.1.23/cgi-bin/hi3510/param.cgi?cmd=setmdattr&-enable=0&-name=1&usr=[YYY] & pwd = [XXX]
in web browser if I type this it works, but not in fibaro :
http://192.168.1.23/cgi-bin/hi3510/param.cgi?cmd=setmdattr&-enable=0&-name=1&usr=[YYY]%20&%20pwd%20=%20[XXX]
Thanks a lot
7 answers to this question
use function urlencode() implemented in lua
or
function urlencode2(str)
if (str) then
str = string.gsub (str, "\n", "\r\n")
str = string.gsub (str, "([^%w ])",
function (c) return string.format ("%%%02X", string.byte(c)) end)
str = string.gsub (str, " ", "+")
fibaro:debug(str)
return str
link="http://192.168.1.23/cgi-bin/"..urlencode2("param.cgi?cmd=setmdattr&-enable=0&-name=1&usr=[YYY] & pwd = [XXX]")
for test urlencode, the decode function is:
function urldecode(s)
  return string.gsub(s, '%%(%x%x)',
    function (hex) return string.char(tonumber(hex,16)) end)
    thanks for the hint, unfortunately I dont how to implement it. Actualy this is what Im trying to get working:
    device = Net.FHttp("192.168.1.23")
    data, status = device:GET("cgi-bin/hi3510/param.cgi?cmd=setmdattr&-enable=0&-name=1&usr=[YYY] & pwd = [XXX]")
    can you pls help me out with the entire code ?
    As it was written above:
    create function
    then in vd make line:
    and finaly call:
    Great, thanks a lot for support :)
    EDIT: Tried right now, and still getting error message on the username and password :(
    Edited by Acho
    Did you remove the space from link around & before pwd?
    Yes I tried as well - no success :(
    The user and pass is surely corecty - coiped from the web browser the working link
    Long shot: are you sure about that url? Google tells me api for this kind of camera is...
    The urls look quite similar, but not exactly the same.
    Their example also includes the authentication at the start of the URL:
    None of the examples has spaces in them.
    Maybe your browser cached the password? Or stores authentication in a cookie? You could try this. Start "New Incognito Window" in chrome, then paste your URL and see if that works.
    I could be talking nonsense because I do not own this kind of device. But I joined other discussions regarding get/post/urlencode and the likes...
