LUA: Extract XML(GET) - REPLACE TAG VALUE - UPLOAD (PUT)
Good Morning Guys,
I need to create a Virtual Device in order to enable/disable some functionality of my devices.
Shortly in need to extract the XML, modify a tag value, re-upload the xml.
I have understood that using "Net.FHttp"  and GET/PUT command im able to RETRIEVE and PUT the XML....
Example: response,status,errorcode = device:GET('URL')
Example: response,status,errorcode = device:PUT('URL',XML)
But how the entire process can be writed in LUA?
1) How to store in a variable the entire XML extracted using teh GET command?
2) How to replace the xml tag parameter ? ex. from enable to disable
3) How to re-upload the modified XML?
Thanks in advnace
Regards
Gianluca
example
    16 hours ago, 10der said:
    example
    Thanks a lot for your example.
    If i understand well this code retrieve the xml and check the status of your cam.
    We can use the "response" variable and replace a value into a tag in the xml retrieved and PUT again the entire code...
    Any idea?
    Edited by Gianluca S.
