Ole 14
I have a couple of questions after having added the Aeotec Gen 5 switch to my system. First, when adding it I get the error message that the device might not have the parameter that the home center thinks it has. Second, the device displays as having a load even when it is switched off. Does this mean that total consumption is added to even when the device is off? In that case I can't use the consumption values for anything.
Thanks!
