knuth 29
When I am away, I would like to be warned about power failures. I intend to install a small UPS (battery backup) covering my HC2 and the router/modem, to maintain communication. The HC2 itself therefore will not sense the power failure. What do you suggest as an easy way to detect that power is out? Periodically turning on some item and checking power consumption? Testing communication with one or several units, assuming that if there are multiple failures they are caused by a power outage? Or is there a simpler way? How would you implement this in a scene? Preferably one that is triggered by the power outage itself, not by a time-based trigger.
11 answers to this question
