How to correctly connect Fibaro Shutter
I am trying to install a Fibaro Roller Shutter 2 at my mom's house. Unfortunately, I am getting myself very confused which cable to connect to which port on the Fibaro since my mom's old switch is very different from the one used in the installation video.
Here is my mom's switch from the outside:
And this is what it looks like from the inside:
I have also created this diagram for an easier understanding how the cables are currently connected:
The green cable is actually green/yellow and should be ground. The brown cable (coming from power) should be load and the blue cable should be neutral. Unfortunately, I just can NOT wrap my head around how to connect this setup to the Fibaro on the right.
Any help would be very much appreciated!
PS: I have also attached my Adobe Illustrator diagram file to this post in case it would help.
Edited by venicenerd
4 answers to this question
All is OK
Green/yellow - PE (EARTH)
Brown - L ( LIVE)
Blue  - N (Neutral)
Q1 - Red? ( motor)
Q2 - Black ( motor)
SWITCH
COM BROWN - L ( Live)
S1 -  switch UP
S2 - switch DOWN
See picture
    Thanks for the help! So if I understand correctly I should wire my switch/Fibaro like this:
    is that correct?
    thanks!
    15 godzin temu, venicenerd napisał:
    is that correct?
    YES
    Thanks, mate!
