Does home center lite & home center 2 works with hikvision ip cameras? which model you are advising?
Hey there,
All hikvision cameras work within HC although you'll need to set them up as ip cameras
please see my screenshot below:
the stream URL changes from model to model but should be something like:
For JPG:
Streaming/channels/2/picture
or
ISAPI/Streaming/channels/101/picture
For Mjpeg:
ISAPI/Streaming/channels/101/httppreview
Or
Streaming/channels/2/preview
  • 4 weeks later...
Hi amurray
Do you have an NVR? I have a NVR with 3 cameras and I cant seem to get the Fibaro app or desktop to stream properly.
Do I use the ip address of the NVR or the individual camera ip addresses? I cant seem to get either to work...
Hey there,
For JPG:
or
For Mjpeg:
Or
Guest sameri
On 5/8/2018 at 9:19 PM, serrzy said:
Hi amurray
I'm 99% sure that if you're using an NVR with onboard PoE, i.e. the cameras are plugged directly into the NVR, then you cannot access the MJPEG streams from outside of the NVR so would not be able to view them with the Fibaro HC. You can get around this by using a standalone PoE switch and connecting the cameras external to the NVR so they reside on the main LAN. You can still record to the NVR but a bit more manual configuration is required. It has been a while since I've done one in this configuration but it is possible.
