VD for POPP Weather Meteostation
Hi!
sorry, after when a new forum structure coming I feel crazy here.
so, I bought Z-Weather (wind speed - humidity - temperature - barometric pressure - dew point - lightness - wind yield - solar yield) meteostation
I have developed raw VD for this device.
I want to share this VD
configuration not simple... but I think you can do it.
change values according to your device
a hard part of configuration - icons
you should change icons for weather
4 - default VD icon
sunny - 1023
most cloudy - 1026
cloudy - 1025
rainy - 1025
1024 - snow
1028 - M/A
VD use
 algorithm for the forecast.
PS: unfortunately there is no wind direction sensor in the meteorological station :(
UPD:
v1 - initial version
v2 - some minor changes
v3 - pressure trend now calculated by 4h interval
v4 - now you can setup icons in the user section
Edited by 10der
version update
6 answers to this question
I am not so happy with this Z-weather. No correct readings.
But I tried your VD and have some problems.
Is this working on your HC2 Version 4.560?
Kind regards
    POPP weathe rmeteostation was sold 1y ago. I am not so happy with it
    now i am using (more than 1y) with
    sorry
    Thanks for the info. But the Qubino is not available anymore
    Hello again. The Popp weather station was not working and I send it back for warranty. Now I found a company who sells his last Qubino weather station. I would like to integrate it in my Fibaro system. Do you have good experiences with this system?
    Thanks for the information
    I have Qubino weather station 2y. all ok.
    but Qubino weather station now discontinued product
    This is the answer from Qubino "We were producing the z-wave part for the weather station, the factory which was doing the weather station closed and for this reason they don't produce the weather station anymore. For now we don't have in plan to go that way as we have other products in the plan for the next year."
    But i found a company who sells the last item
