I like to control my sunscreen and robotmower depending the weather type.
so sunscreen out when is clear not clouded
sunscreen in when it will be going to rain.
robotmower will be out when it is not going to rain or raining
how can i link this to my scenes
hendo
Hi @Hendo ,
Which HC do you have? Are all those devices connected to it?
    I have a HC2 and sunscreen is connected to the HC2
    The mower is connected to a fibaro wall plug
    hendo
    Have you tried setting up a simple magic scene using weather as a condition?
    i tried but it didnot work.
    Because it is looking at the moment you like to activate your device, when its rainy it will not close the window or let the mower go out. But when it is sunny it should work, but only when it stays sunny or in case of mower , not rainy.
    It should work with a delay so its not changing states every minute.
    hendo
    can you give an example how i should do this?
    hendo
    That is a very useful suggestion!
    I've reported it to our engineers and we'll be sure to give it a closer look. :)
    Stay tuned and keep your fingers crossed!
    " to "
    Temat został przeniesiony z "
    " do "
