Slim! domotica 0
Hi, I'm trying to connect a Danfoss wall thermostat to a simple on/off module, but up till now I haven't been succesfull.
Connecting the thermostst to the HC2 is not a problem, loaded and got a perfect view with two thermostats in the software, one for the actual value and the other for the desired value.
The on/off module is visible as well, so no problems with that issue.
the purpose is to switch the module to "on" when the desired temperature is higher then the actual temperature and switch to "off" when the actual temperature is higher then the actual temperature.
Can anybody help to solve this issue?
Thanx in advance.
