Creat a Predefined variable from a scene
Ik know now how to creat a single variable from a scene
local http = net.HTTPClient()
        http:request("http://127.0.0.1:11111/api/globalVariables", {
        options = { method = 'POST', headers = {}, data = '{"name":'..data_v..',"value":"0"}', timeout = 2000 },
Now i want to creat a Predefined variable from a scene
I though to by replacing it with this line it will work, but not
options = { method = 'POST', headers = {}, data = '{"name":'..data_v..',"value":"Empty","readOnly":false,"isEnum":true,"enumValues":["Empty","Test1","Test2","Test3"}', timeout = 2000 },
Please can someone help me
Thanks Kage
I think you have to create it first, like a non-predefined (so only name and value). Your first command is correct.
Then modify it to become "predefined" by  using PUT instead of POST, I think the rest of  your second command is correct (setting name, value, isEnum, enumValues)
EDIT: I've found some code in my collection of snippets:
Edited by petergebruers
